thermador doubleoven repair question
thermador double oven model scd320tb lower oven does not work have replaced lower oven board and bake element and the oven still does not function,what am I failing to analyze correctly . Thank you
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=scd302tb
I am assuming everything looks normal just no heat.
Getting tech info on Thermadors is difficult so the following is a bit of a guess.
If you look at Section 4 Item 12 they show a thermostat (may even be a fuse).
In their description it is a high temp cut-out, odds are this is open.
Thank you the problem with the thermador double oven was the lower high temp cut out,fuse replaced it-worksfine bobgto
