Oven was put into the self cleaning mode. Since that time the cooling motor will not shut off, the functions: oven, convection oven, and broiler do not work, and the oven door will not open. I have replaced the high temp cutoff switch which did not fix the problem. I have also disconnected the latch unlock and lock switches with no luck. Can you help?
The unit will stay locked with the fan on if the unit feels the cavity is too hot to unlock the door. This could be a problem with the oven temperature sensor, which is the proble sticking out of the right, rear corner of the oven, or it could be a problem with the plug that connects the sensor onto the relayboard (J10).
KC
Need your help, my microwave Model # gh8155xjq1 handle at top has broken need to take off and replace new handle Part # ap3033588
The dishwasher will not start, no green lights come on. We have checked fuse and electrical outlet, but they are fine. Can you help with the problem?
