Thermador oven problems
First off, the oven thermometer is not reading the same as the as the setting on the oven setting. That is an easy fix. I hope:confused:. Buy a new oven thermometer and compare them.
Next, I just recently heard a louder then most time pop from the oven lighting. It has done this before. Now, I need to tell you that I am on Propane with the proper orifices installed, I believe. Otherwise it would have been noticeable. I have heard through others that the propane line that feeds the unit should be taken off and cleaned. I just don’t know what to clean. I don’t want to do something stupid like blow pressured air through the lines that can damage something. The loud pop is disturbing and sounds like it might be and ignitor issue. Any thoughts??? Thanks for the help in advance.
                                          Bob
