Thermador oven won't heat
After beginning to preheat, the oven turns off and gives error code F 34.
The oven can be turned on again and set to a new mode and temperature and will usually again turn off and give same code. After several attempts using different modes and temps, sometimes the oven will preheat to desired temp. and work. This is an electric oven. Very frustrating. Thanks.
