Thermador PRG36 Range
I’ve seen some other posts on similar topics without replies. Thanks in advance for any help.
My PRG36 Range Oven will not heat/ignite. Burners, griddle, broiler, all work fine. I pulled out the bottom to get to the igniters and there are two, an ignition device
http://www.appliancepartspros.com/bosch-ignition-device-644424-ap4309945.html
and an ignitor
http://www.appliancepartspros.com/bosch-ignitor-418885-ap3194444.html
The ignition device doesn’t glow, and the ingnitor doesn’t spark. The gas does turn off when the oven doesn’t light, which leads me to believe the board is ok. Can anyone confirm if that logic is sound?
