Thermador range - no gas flow to 1 burner
1 burner on my gas range no longer lights. the ignighter is working, but there is no gas smell or hissing noise coming from the burner. does anyone have any ideas on what i can do or what type of repair person to call if it isn’t a one girl job?
Is it an XLO burner or just a regular one?
If you do know how to use a multimeter and a simple tools then you most likely can do the troubleshooting and repair yourself.
If you would prefer to call a pro, then make sure he knows how to work with Thermador appliances.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232059
