thermostat
right (main) oven will not shut down (cycle) when reaches operating temp. I would specualte that the thermostat is defective, your companies parts book only shows 1 thermostat and partpros where unable to decide if both sides are the same. Right oven (main) is self cleaning and left oven is not-that is the only difference. please let me know if I can order the thermo in from parts book.
thanks tim
— Begin quote from timothydonovan;128503
thanks tim
In many cases the actual part number will be stamped
on the outside of the part itself. Get all of the numbers
off of the outside of the control itself and post them here.
The part number should begin with WB.
