[SIZE=3]Whirlpool double oven: Oven control panel went dead after self cleaning.[/SIZE]
[SIZE=3]We reviewed the forum and tried several of the checks recommended. We removed the oven from the cabinetry and tested thermal fuse behind the control panel and the 2 thermostats on the back of each unit with an ohm meter. All seem to be fine. Is there anything else we should check before we order a new control panel? [/SIZE]
[SIZE=3]Anxious to bake coookies![/SIZE]
