Tom
Washer was not draining on spin cycle. Was draining on rinse cycle. Replaced timer now wont drain at all. Control board problems or pump?
The best way to check is to use a meter and see if 120v is getting to the pump when it is supposed to be draining. If so, replace the pump which I think is likely the problem.
