My washer fills with water on every load size then stops. It won’t even work if I try to start it on a different cycle. It won’t spin or rinse. I check the lid switch and that is fine, it clicks when i open and close it. PLEASE HELP!!!
By pass the lid switch to be certain it is not the problem. If it is not, post a model number and lets see what else we can come up with.
How do i bypass the lid switch?
— Begin quote from sidfink43;262382
I don’t know because we do not have a model number, so we don’t know what your machine looks like.
Post the number and let’s see what you got.
sidfink43 said:
I don’t know because we do not have a model number, so we don’t know what your machine looks like.Post the number and let’s see what you got.
Kenmore 90 series washer won’t spin/drain. It fills/agitates, but when it hits the drain or spin part of the cycle it just stops. Thought it would be the lid switch. bypassed it with a wire in the plug, but nothing happens. What do I try now? (im not the original poster - but same problem). Model 110.20902990
