top loader washer leaking at tub seal
Our washer is leaking from the seal at the tub. I’ve removed the front panel and noted the leak. I’d like to clarify what I should order to make the repair. As I understand it, what I need is:
[LIST=1]
*]mounting stem repair kit
*]tub bearing kit
*]spanner wrench
[/LIST]Did I miss anything?
Thanks, Rob
I submitted a question this afternoon with no response regarding what I think is a tub seal leak as well… no one has answered… does your tub seal leak right at the outset? my leak doesn’t start coming out the bottom until the tubfills about a quarter of the way… then it starts coming out the bottom at a pretty steady clip…
because of the cost, I am hesitant to get the parts IF there is a chance it might not be the seal…
P.s… there is a great video clip on replacing the tub seal… that I think is somewhere on this site …or at least they have a link to it…
