I have an electrolux double wall oven. The bottom element, in the top oven is not working. I’ve replaced the element but the problem is the same. I don’t have a wiring diagram,so I don’t know what to do next,or if the problem is with a thermal fuse,control panel or ?. Can anybody give me some advice ? Thanks, Bill
— Begin quote from Gene;310290
Bill,
Does the top (broil) element in this oven work?
Hello Gene,The top (broiler element does work
Bill,
Hello Gene,Yes the top (broiler element works fine.
— Begin quote from bill1943;310296
Hello Gene,I’m not sure if I’m replying to you correctly,but the broiler element does work correctly
There is a thermal circuit beaker but it will shut off both Bake and Broil elements. So the problem is a bad relay board for the upper oven. It is located inside the control compartment and the oven has to be removed from the cabinet to access the part.
- The upper oven relay board AP2127302
— Begin quote from Gene;310320
- The upper oven relay board [part]AP2127302[/part]
Hello Gene,Thanks so much for the info. I didn’t have a wiring diagram,so I just didn’t know what part would allow the broiler element to work and not the lower bake element. Thanks again for your help, Bill
You are welcome Bill. Keep us posted.
— Begin quote from Gene;310645
I can’t thank you enough, Bill
— Begin quote from bill1943;310353
Hello Gene,I wanted to let you know that I replaced the relay board for the top oven and it now works perfectly!! Thanks again for your advice.I think I probably saved $400-$500 by doing it myself. Bill1943
You are welcome Bill. I’m glad you were able to fix it.
