Touchpad substitution??
The black touch pad (below) for this double oven is back-ordered until mid-June, however, the touch pad for the stainless steel version IS available now. My question is:
Is it possible to substitute the
SWTCH-MEMB - Silver Touch pad Part Number: AP4316576
for the
Touch Key Glass, Dbl, - Black Touch pad, Part Number: AP4362220??.
It appears that they are basically the same part, maybe slightly different color layout, but I can’t be sure.
i recently replaced the temperature sensor in my oven after receiving a F3:EO error code i turned the oven on brought up to 450 and cut it off with no code. a little later went to use and now it gives same code and will not come on and get oven to temp please help thanks
