travis1 Door latch
:confused: The door latch has been hard to open for some time but now it is closed with load of finnished dishes and I can not get it to open. I removed the wooden custom panel and the sheet metal covering the insulation so as to look up into the push bar area that is to unlatch it .That bar feels loose . Is their a way to use a screw driver to get up there to the latch? After I get it open I need to see what I need to fix this problem.
Try to pull the top of the dishwasher out of the cabinet for a few inches to reach the latch strike (#31 on the [B]diagram[/B]).
