trouble with ice maker shut off arm
I am having trouble with the shut off arm on our ice maker. when it cycles to make ice it does not go all the way down and you have to push it down to continue making ice. is there a fix or does it need replaced?:rolleyes:
The ice maker is mounted with the two screws to the left side wall.
The spring is #2 on the following diagram.
I had the same problem but when I took the ice maker apart, the spring popped off and I have no idea how to put it back on. I see the part on the diagram but it does not show how to put it back or where it actually goes. Can you help me?:frowning:
The up arrow on the touch pad on my Kenmore stove the does not work correctly. I have to hunt around for the correct spot to get it to work, some times it is as much as 1 inch off and some times I cannot get it to work at all. All of the other buttons work fine. Do I need a new touch pad or is there some kind of cleaning or adjustment I can make?
I need to reinstall the spring part listed above, but am unable to figure out how it is oriented. Does anyone have a picture that shows how the icemaker looks with the spring installed? Alternatively, could someone describe how to install it? I’ve looked online for the last week and cannot find anything that gives a clear indication on how to assemble it.
