The griddle for my cooktop will not ignite until the dial is turned to 350 degrees, once it does ignite the griddle does not heat to the desired temp. and turns off prematurely(thinking thermostat went bad) hate to quess wrong, they not cheap
Related topics
troubles with griddle | 1 | 932 | November 6, 2013 | |
Thermador Cooktop Griddle Doesn't Heat Properly | 2 | 1686 | May 15, 2013 | |
Griddle ignites then shuts off immediately | 1 | 1023 | July 26, 2015 | |
Griddle ignites then shuts off immediately | 1 | 2043 | July 26, 2015 | |
cooktop | 1 | 845 | February 6, 2011 |
