I have a maytag electric dryer displaying eroor code tS when you try to start it. Any ideas?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE6700AYW
Here is a service manual, tech sheet and a tech bulletin
http://www.servicematters.com/maytag_library/docs/16025911.pdf
http://www.servicematters.com/maytag_library/docs/16026881.pdf
http://www.servicematters.com/maytag_library/docs/TDL-0141-B.pdf
I would try resetting the error first, just in case it was just a false error, see the tech bulletin.
Would also clean and check your vent system.
