Typical resistance?
Can someone PLEASE tell me the typical resistance I should "see" with my ohmmeter when measuring the oven temperature sensor at room temperature?
F3 is the fault code displayed. 1K ohms is the resistance measured.
Thanks, das
Generally 70 degrees will give you 1080ohms. Try also taking the reading at the connection point on the control board as the wire connectors can affect the actual reading the board is seeing.
That is where I measured the 1K. To me it seems like the control board is the next
suspect. Also can someone tell me where I can get a wiring diagram? I’ve misplaced
the one I had moving for the second time in a year.
Thanks, das
