Upper Sray arm does not spin
The Top rack spray arm on my dishwasher is not turning when the water is being sprayed through it. I have taken off and cleaned w/o any luck
The system is designed to operate only one spray arm at a time. During the first wash and first and second rinses, only the lower spray arm operates. In the second wash, third and fourth rinses the spray arms alternate about 90 seconds.
If this is what happened with your dishwasher then there is nothing wrong with it.
Check how freely the spray arm is moving.
Make sure the check ball in the pump is free of any hard water deposits and moving freely as described in the attached file.
