Very srong smel of gas
Wen I turen on the stove it takes long time for prehiting with smel of gas,after a wile wen it turned on the all kitchen was shaiking.The smel is ther even wen the oven is hot and warking.I have no problem with the range and wen the oven is not on ther is no smel.
Most likely the problem is a bad oven Bake igniter (#17 on the [B]diagram[/B]).
It comes without the mounting bracket. You have to use the old bracket. Be careful not to touch the igniter coil.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=647568&&model_id=20545
— Begin quote from Gene;107114
Most likely the problem is a bad oven Bake igniter (#17 on the Replacement parts for AMANA ARG7302WW | AppliancePartsPros.com.
  • The Bake igniter [part]AP4041245[/part]
Here are the breakdown diagrams and [URL="http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=647568&&model_id=20545)
Gene./quot
Thank you it works perfectly
You are welcome. I’m glad you were able to fix it.
