Viking range ignitor won't stop
Good spark, quick flame on all 6 stove burners. The left 2 burners seem to spark together (regardless of whether front/back is turned on); similarly, the center & right 4 burners spark together.
PROBLEM: The ignitor keeps sparking even after the burner has lit.
Is there some kind of sensor that tells the stove that the burner has lit and
that it should stop sparking? Does it go bad? P/N?
Something else? Ground? Ignitors need cleaning? Ignitor module somehow bad?
Apologies if this was covered before, but I couldn’t find this problem described.
Thanks! Dave
