Wall mounted convection oven
Control panel beep. The control panel beeps when you put in a command but there are lights in the panel that do not light up at all. Is the whole panel your part # AP4089607 need to be replaced are is it something else.
If it is the control Panel , is this something a homeowner can do.
Thank you in advance.
wmwsmw
