Wall Oven Problem
My Oven has the following problems. No lighted display. Only cook mode that works is Bake. Oven light works. I believe I need to order a Control Panel #AP378762. My question is could the clock AP369030 also be bad because I have do display lights at all? In other words can a bad control panel also cause this oven to have no lighted display?
The clock is the control board. the control panel is just the decorative part.
Nat
door does not close
