Top oven just stopped working the other day out of the blue. Bottom Oven works just fine. Top oven (broil and bake elements) will not heat at all. Self Clean will not work either. The clock and display work just fine. When you press bake and set the temp and you can hear a click to start the elements but no heat (you hear a click under normal use even when it cycles the elements on and off while maintaining proper temp and upon startup). About another minute later another click and so forth. The display just shows 100 degrees, normal starting display temp.
Related topics
GE Wall Double Oven Top Oven Not Heating | 0 | 2992 | January 11, 2008 | |
oven doesn't work | 1 | 1284 | July 2, 2011 | |
Top wall oven stopped heating | 7 | 2505 | January 4, 2012 | |
Oven won't heat. | 0 | 1023 | December 10, 2009 | |
top oven problem | 1 | 892 | April 14, 2008 |
