warm wash water
Washer will not wash in hot water only. With the switch set for hot water wash, the washer starts to fill with hot water for a few seconds then the cold water valve opens and I get warm water. Temp control switch check out OK. Where does the washer sense the temperature of the washer? There is an Automatic Temp Control board in it but I cannot figure out where the temp sensor is.
