Warm water does not work
I have a GE WHSE5240DIWW washer. The problem is when the warm water setting is selected, I only get cold water. When on a cold setting, I get cold just fine, when on hot, it is very hot. The washer does not switch back and forth between the cold and hot to give me warm like it used to. Could it be the selector switch? I don’t think it is the inlet valve since hot and cold work properly. Thanks.
Anyone have any ideas?
