waser makes loud screeching while spin cycle
My washer makes a loud sceeching sound only in the spin cyle. Any ideas why?
When seal is bad does pully wing goldish brown grease/oil all over the bottom of the machine?
I have a similar problem SCREECHING
1st problem is the drive belt burnt at the small pully side and broke from a freeze up or something.
Put a ribbed type auto belt on that we matched to see if the tranny blew or if it still spins. It spins and agatates. Does full wash cycle - wash, rinse, spin.
Now getting Very Loud screeching when it starts to spin and continues until it reaches full speed - then gone.
Also If I put some pressure pushing the motor back is is not as loud, still screeches but reaches full speed quicker
Brakes fine and quiet.
Machine has a metal drive pully and it Sounds like metal on metal at the bottom of machine.
No metal filings under the machine.
Occosional burst of the same screech during wash / agatate/ rinse cycle.
Completes full wash cycle and runs pretty good but the screeching sounds like it’s gonna blow up!
Helpl I want to fix it, 20 years new and counting.
Thanks.
