Washer board fried?
Motor not turning. Tech came and said board was fried, probably an electric surge. Cost to fix $400++.
Is this the "speed control" shown on the Tech Sheet? If so it would be easy to access and replace.
TIA
Model No. correction: 417.44142400
That is probably what the tech meant, since this part fails somewhat frequently on these machines, but since you have the tech sheet I would try to do the trouble shooting and diagnosis tests before commtting the funds.
Here is the part
AP3967975
and here is a service manual which will show you how to do some testing.
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
