The wash cycle starts just fine, and sometimes will go the complete cycle insofar as time which is 6,9,12 or 15 minutes, but it is sometimes shorter. When it comes time to drain to start the rinse cycle, there is a clunking sound. I press the Stop / Start / Pause button, turn the dial to spin, and it drains just fine until empty and then the clunking sound starts again. I then select the wash cycle and it fills and washes (rinses). I then manually select the spin cycle and it drains OK, until it finishes draining and the starts clunking again. I then press the Stop / Start / Pause button multiple times (usually about 30 times, until the clunking stops) and the spin cycle starts and I’m done. This manual operation is getting old. Any help would be appreciated.
Thanks…John
