washer does not advance in cylce durring rinse cycle
Hello,
I have a Maytag Washer Dryer stacked unit, SE1000. The washer gets stuck on the rinse cycle at "2", and does not advance. I can manually select a lesser time when it’s stuck and get it to advance to the spin cycle. I thought replacing the circuit board with the timer built in (I’m pretty sure it is built in as I can find no other timer in the unit), but this did not fix the washer. Is there something else I should be fixing?
Thank you,
Jasollitto
it was the mixing valve solenoid, the cold water part of the valve would not open, so the tub could not fill during the rinse cycle, and that prevented it from advancing.
