washer does not agitate when in wash cycle
The washer does not agitate when in wash cycle. I need help to figure out what the problem is and how to fix it.
If the machine will spin, the problem is probably in your agitator dogs which you can change out by removing the top of the agitator.
If the machine will not spin your problem is probably a broken motor coupler.
Good luck, and if you need more infopost your questions and let us know whether or not the machine will spin.
