Washer does not spin
Washer operates normally except it will not spin. Washer has seemed to go out of balance more than normal in the last few months.
I pulled the brake on the bottom of the machine and it appears ok. Checked the rotation on the motor and it goed one way for agitate and the other way for the spin cycle as it should.
My wife heard a noise before the machine quit spinning but I can not identify if this is related or when it may have come from.
I see the breakdown of the machine and it shown a snubber in the brake mechanism. I did not see this when I took the brake apart. Should there be one?
If I rotate the drive pully on the agitator it move the agitator. If I turn it the other way the agitator does not move. Does this indiicate anything?
Thanks for your thoughts
