Washer Does not Start in any Position
I have a Kenmore series 90 washer. I’ll describe what happened to the washer as I was present when the washer stopped working. I loaded the washer turned the knob and pulled it to start the machine. Water started to come and and then stopped. I pushed the knob in and turned it one more click, water started flowing freely. After the washer was full of water, the motor started but the agitator did not move. I pushed the knob in to turn it off and then moved the knob one more click. I then pulled the knob back out and the washer the motor gave one grunt and then nothing worked. I removed the wet laundry and siphoned out the water. I tried to start the washer again to find out if it would fill up with water and it would not work. I tried all positions and nothing still works. Any solutions on how to go about finding out what is wrong and fixing it is greatly appreciated. Thanks
