how do you change the door switch???
Your model does not have a door switch. If you mean the lid switch you take out the two screws that hold the console to the cabinet and flip it back. Disconnect the lid switch plastic coupling and flip out the two clips that hold the cabinet to the back. The cabinet will now tip forward to give you access to the lid switch.
Good luck, let us know if you need more help.
