Washer drains will not spin
I have a KitchenAid clothes washer that will empty the water but will not spin.
The motor is running but the tub will not turn. This is during spin cycle. Before I start throwing parts at the machine does anyone have a suggestion what to check out first.
motor coupler. Heres a link to a video showing how to replace this.
http://www.appliancehelponline.com/servicemanual.html
Thanks badbackguy. I pulled the motor just moments ago and sure enough it was the coupler. All the pins on the transmission side, gone. Vibration damper in between shot. New parts are on the way. I am going to go to the link you sent and check it out. Thanks again.
