The basket stopped spinning so I replaced the motor couplings and later the transmission. After replacing the transmission and putting everything back together, I ran the washer on a spin cycle and noticed that it spun out of balance. I have since replaced all the balance springs but not the counterbalance spring. All of the springs appeared to be in good shape though. None of them had come loose or were broken.
It still spins out of balance. Not horribly but it’s noticeable.
I talked with a tech on a repair site and they suggested I take the transmission back out and put it back in because it could have been installed incorrectly but I can’t imagine how that could happen.
Any other suggestions? If I need to, I can make a video of the spin and upload it I think.
Yeah, it’s pretty hard to put the gearcase in wrong. You could have a damaged tub/basket. You could have damaged or missing suspension pads or tub suspension pads. Or a misaligned skate plate.
I’ll get video today. I’m gonna have to take this thing apart again to check all of that aren’t I?
I haven’t fixed it yet. I know the machine was a different machine than mine. I was only using it to show about how much my machine was wobbling on the spin cycle.
I’ve now replaced the suspension pads and suspension pad kit and it still does this. Is this normal? Here’s a video I made. If it’s not normal, I don’t know what else to change.
That looks pretty normal to me. Can you feel the vibrations in the floor or is it shaking the machine?
The top of the basket is a balance ring and it is half full of fluid. It helps balance the loads, but when they are empty it makes the whole tub and basket go through this kind of vibration pulse that is constantly repeated as long as it spins. Its not enough to be able to notice unless you have the lid open and can see it. I’ve never timed this pulse, but everyone of these washers has it.
Its very important to level the washer and then lock the front legs. Then I usually tip the washer forward so the rear self leveling legs drop down and set it back. If they are on a good solid floor they run smooth.
The machine is level. I’ve checked that. I really only feel the vibration in the machine. I’ve run a couple of loads and it feels ok to me.
Is there a way to refill the balance ring or does it have to be replaced?
No, its half full by design. When the basket stops spinning you can hear the water stop about half a second later. Its a neat system. Before this most companies used concrete rings and blocks. Some still do.
BTW this balance ring system has been around since the 80’s.
Probably not. It would have to be cracked or have a hole worn in it. The only cracked ones I ever saw had been subjected to temperatures of -10 degrees F. for days.
