Washer extracts water as fast as it comes in
Our washer has worked great till now. When it fills with water it extracts the water as fast as it is coming in. The tub is holding no water. Like I said it has been great for about 5 years till now. Any help would be appreciated. Thank You
Either the pump is on all the time or a siphon has been created in the drain pipe. The siphon is created when the drain hose is too low in the pipe, or when air is shut off from the drain pipe. Check all that out.
