Washer filling
I have been having filling issues with my washer it does not stop filling at the correct water level. I have replaced the press. Switch, replaced the water valve and the press. Switch hose and is still doing the same thing. Should I replace the control board? Please advise I need to have this repaired.
Wil
Wow, what you did should have done it.
Try this. With the cabinet off and the pressure hose unhooked from the tub and the hold in the tub plugged, start to fill it. Blow into the hose and see if that stops the water from coming in.
If not, the control unit is the big suspect.
