Washer keeps stopping
Model # WASE5210B3WW
Serial # TD9454036
Hi. I know there are many threads which talk about this but, they all talk about some sort of error code which I don’t think mine is doing. I also don’t have a manual for it unfortunately. It basically stops whenever it feels like and I always have to push the start button for it to continue. The lights also turn off when this happens. I mean, it gets the job done but its a big inconvenience having to keep checking on it. I’d appreciate any help! Thanks.
Hello.
From what you are describing most likely the problem is - bad control board. It’s relatively easy to replace.
Remember that all parts purchased from AAP, are returnable.
The control board AP3204054
Here are the breakdown diagram and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5131412
Post results.
