Washer Leak from the bottom
Okay so I discovered a leak in my washer today coming from the bottom of the machine. Any suggestions on how to narrow the leak down and get parts for it if needed? Thanks for help:confused:
Remove the front panel and have a look. The 2 screws at the bottom front corners hold the panel on, Remove them, Take a putty knife and go in between the top and front panels and gently pry it down. with it removed, run a cycle and see where the leak is.:slight_smile:
How hard is it going to be to separate the wash tub from the rest of the washer motor and trans? I’m just trying to figure it all out before I actually dig into it. I found the parts which I will get tomorrow.
Remove the agitator, clean the shaft and the hub area, remove the 2 bolts in the hub and block, remove the block, Lift the tub out of the washer, Remove the seal (both pieces) and clean up the area, When reassembling the washer, the only trick is getting the block back into the correct place.:slight_smile:
