I’m getting lot of water on the floor during the spin cycles. Water seems to be coming from the front.
How do I diagnose the exact problem so that I can think about whether to fix this or not?
Thank you.
Thank you.
I guess I’ll try to take it apart and see what I can see.
I looked underneath and the leak seems to happen when the pump is NOT running AND when it is running. Water appears to be coming from the hole where the metal rod from the motor enters the pump.
Will a new pump fix this? How hard is it to replace? It looks like you can just disconnect the hoses and slide a new pump on?
THANK YOU for any help
