Washer leaking
Whirlpool washer leaking during high speed spin. Only a few tablespoons of water but a pain the neck. I have run a few empty loads and it seems to stay dry. When a full load of laundry is in, I get water under the machine. I pulled the bellows off, no sign of holes or tears. Any thoughts?
where do you see water? did you remove the toe panel and look? is it excessively loud in spin?
When I took the front off the bottom of the concrete counter balance was wet. Water was dripping, but again only while the spin was going. I removed the counter balance and it only seemed wet right above the center bolt that holds it on. I reassembled the machine and ran the same load again a medium spin speed and it dripped but not as much. Just ran the same load a third time but at slow spin. Still dripped but again much less than prior two loads. It is not making any noise differently that it has since it was new.
