washer leaks at base of tub in the center
My washer is about 12 years old. It has a leak at base of tub in the center where the drive attaches to the actuator. There is also a lot of slack in the two drive belts which I have identified to order and replace. But I am having trouble identifying the parts for the tub that are related to the leak part of this problem. Can anyone help. I have looked at the diagram and do not seem to find what I need.
— Begin quote from sidfink43;127067
See if this is what you need.
[part]AP4390013[/part]
Also here is the service manual for your model.
http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf
This is a pretty big repair and requires a special tool, so given the age of your machine you might want to consider replacing it instead.
Thanks, that seems to be the part and I see the tool needed. I appreciate the help.:slight_smile:
Glad to help, good luck with it.
hey Guys, hoping someone out there can help me figure this one out. all the cycles work fine except for the agitator kicking in when its supposed too. the coupling grooves are great and so is the belt. in fact, when its in the agitator cycle (all it does is humm) I actually am able to take a flat head screwdriver and push the belt in the direction it should go, then it takes off by itself and works great. so whats up? is the belt to tight? something with the clutch? any thoughts greatly appreciated. thanks, Glenn
anyone have any ideas? I tighened the belt today but no help. anyone, anything? please help. Glenn
