[SIZE=5]i need some advice on this my washer is leaking on the floor when i start the wash cycle and i can tell that the water is comming from the tub, so just what is causing this and what do i need to repair this and is it very hard to repair? [/SIZE]
Here’s a breakdown of your machine http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177391
Most likely the problem is in the seal (on the tranny page)
and they can be a pain in the rear to repair, but it’s worth it once it’s done.
Nat
