Washer lights up but won't do anything
The washer would start to fill and wash but would kick out and the start button would flash. I could also manually run a load of clothes by selecting soak, rinse/spin, and drain/spin. I ran diagnostics on it and it said the control board should be replaced, code EB3 "low voltage, if voltage is okay replace control board". The voltage at the receptacle is 118 volts.
Today I replaced the control board with a new one and the lights will light up, but the washer will not fill or even drain and spin. The door locks and the start button flashes and in a 10 seconds the door unlocks. I ran diagnostics again and again I am getting same EB3 diagnostic code. I took the back panel off and checked all my connections and everything is connected and tight.
Did I just get a bad control board? or is there something else I should check?
