I have frontload washer make loud noise when It spin. I just replaced new vibration shock absorber but not making better. Thanks in advance
thanks fot your help. today I just disassembly outer tub and there is the shaft attached to the spider ( 3 wings ) likely 3 arms bolted to inner tub. and 3 arms were broken off , so the shaft is not holding the inner tub. actualy I look in part ( diagram number 4 ( wshr tub, motor) the part AP2107258 is $243.56 + shipping , I dont know what should I do right now . thanks again
You probably also have bad tub bearings, makes the repair too expensive.
