I have an Amana top-loading washer that I purchased used. I have had it for about 4 years. I am not sure when it was manufactured. (From inside the lid, lower right) Model number: LWA30BW, MFG NO. PLWA30BW,
Serial R 9809035582 (is the 98 the year of mfg?)
Anyway, the machine has worked beautifully till now. Now, it only works on delicate. I can run a load just as usual, fill the tank (fills fine), but the timer doesn’t seem to go. It doesn’t start to agitate, and doesn’t spin, even when I advance the dial manually.
Is this the timer going/gone bad? Or is there something else it could be? nothing else seems to be an issue. It appears to work as it is supposed to when used on delicate.
