Washer not agitating under some cycles
If I run the regular wash cycle, the washer fills with water to the appropriate level, but does not advance to the agitation cycle. If I move the timer manually, the water drains from the washer properly.
If I run the rinse portion of the quick wash cycle, the washer fills with water to the appropriate level, agitates, and engages the draikn cycle. HOWEVER, although the washer drain is opened for the water to go out, the washer does not spin until I open and close the top once.
Does this sound like a timer issue? Or is there something else I should consider replacing, such as the circuit board?
