My Matag washer only works on the Perm Press Cycle. It’ll take water on the normal/heavy duty cycle but won’t continue after it fills. Before I dig in and start replacing the switch I thought I’d better check and see if I might be overlooking a fuse or something.
Thank you [U][SIZE=2][COLOR=black]sidfink43[/SIZE][/U][/COLOR]! I disconnected the contacts and cleaned them with some contact cleaner then reintalled them and everything worked properly.
Thanks again!
Great, glad that worked and thanks for the update.
