washer problem
water flows out of soap dispenser. owner has been using liquid soap. tried runnig several cycles with no soap, no effect.
It might be helpful to pull the top off and watch as it goes through a cycle. You may be able to visually locate the source of the problem. Just remove the three screws that attach the top to the back of the machine, and slide the top back and off.
thank you, bottle cap stuck in filler tube.
You just saved yourself about a hundred dollars! Well done.
